It is currently Sat Jan 19, 2019 3:37 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sat Dec 02, 2017 4:05 am
Sorry I am late to the party but I changed my email about a month ago and could not find my Breitlingsource password until this morning. I am glad that WatchFred found my post above from 1-1-2014 as I have not done another Pult crystal since then and did not recall some of the fun details until now. So, after nearly 4 years, my prior explanation is the best I can do at this time.
Good luck, Craig
S. Craig Bergsma
PostPosted: Sat Dec 02, 2017 1:11 pm
Likes: 4 posts
Thanks Fred for the link. I actually searched the net and didn't find this thread. And like you I broke one of my crystals.
Craig, My question is how to install the spring and bezel together on the top of the crystal? Where does the spring go? Is it just on the top of the crystal and press the bezel in? I tried but it didn't work. To clarify, I attached the photo of the two pieces (Bezel and the spring), I don't know how to install them? The crystal and the inner bezel are perfectly and sharp in place.
PostPosted: Sat Dec 02, 2017 2:15 pm
The honest answer is I do not recall. At 73 I am lucky if I remember a watch I worked on 4 weeks ago let alone 4 years ago. However, I think the crystal goes in last?
S. Craig Bergsma
2 people like this post.
PostPosted: Sat Dec 02, 2017 2:17 pm
Likes: 116 posts
Liked in: 137 posts
Lots of years of experience Craig.
PostPosted: Sat Dec 02, 2017 3:15 pm
Likes: 899 posts
Liked in: 1110 posts
that’s what u said in 2014 iirc. you weren’t too amused with changing that crystal ;)
PostPosted: Tue Oct 23, 2018 5:43 pm
Likes: 4 posts
As always with Breitling watches, I figured out how this work.
Here was my problem. I was putting the bezel spring underneath the bezel, because I thought the bezel is so thin and has no wall that I can't attached the spring to it. That was the reason the bezel was kind of soft.
After several attempts, I tried to push the spring to the back of the bezel and make it to stick to the very thin wall. It worked eventually. So the process is the following before I get Alzheimer and won't remember:
1. Stick the spring to the back of the bezel. This will make sure the bezel with be firm.
2. Put the crystal over the bezel and press the glass into the case.
Before pressing the glass into the case though, you have to put the innerbazel inside the glass. In order to have the innerbezel is aligned with the Tachy of the dial, you should:
1. install the movement and dial inside the case. That way you have the 12Hr sharp on the top,
2. now you only need to align the 100 on the innerbezel with the 12Hr of the dial and press the glass in. There is no need to do this 4 times as some expert had written earlier. Once done properly, it should work.
I hope anyone who is looking to solve this problem in the future, can figure out the solution through this thread and not to invent the wheel from scratch because I also get Amnesia or Alzheimer.
Users browsing this forum: No registered users and 7 guests
All Watch Sites
