It is currently Thu Jan 24, 2019 3:46 am
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Breitling 1191
PostPosted: Wed Jun 07, 2017 2:55 pm
Likes: 290 posts
Liked in: 514 posts
buddman wrote:
So not radium then I guess.
+1
Radium doesnt need a 'light charge' to be luminous in the dark , so its Tritium or newer
PostPosted: Wed Jun 07, 2017 3:07 pm
Likes: 151 posts
Liked in: 130 posts
my HIGHLY limited knowledge is that this is what radium does -- glow under UV then rather quickly stop glowing.
PostPosted: Wed Jun 07, 2017 11:01 pm
Dracha wrote:
+1
Where are you getting your information from? The article I liked to from one of the worlds more serious Rolex collectors says Radium will need a UV light source to glow. You can even see that the lume has broken down in places by comparing the UV photos to the ones I did with the microscope.
PostPosted: Thu Jun 08, 2017 8:29 am
Well it's Radium!
Where do we go from here?
Anyone else still on the fence?
PostPosted: Thu Jun 08, 2017 1:05 pm
Likes: 290 posts
Liked in: 514 posts
Either your measurements are off or mine are , here is what i measure on a 1960 radium dial
PostPosted: Thu Jun 08, 2017 1:48 pm
Online
Likes: 905 posts
Liked in: 1111 posts
Rene, the 20-25 range is fairly typical ?
73 is extreme, I think, we should check w/ Jack or Roy Davidoff, who did a ton of research ?
PostPosted: Thu Jun 08, 2017 1:57 pm
His reading is only 1.38 so something is off with his reading
Any more thoughts on my watch Fred?
Thanks
PostPosted: Thu Jun 08, 2017 2:39 pm
Likes: 290 posts
Liked in: 514 posts
Before stating my reading is off , do a search and find out how much 20 microsiev really is , ive done some searching and there are videos of old military watches that show in the 1.2 to 1.9 range , 20+ is cause for alarms to go off
PostPosted: Thu Jun 08, 2017 2:41 pm
Likes: 290 posts
Liked in: 514 posts
Ps fred , 73 is the cpm count , 1.38 is the siev count , the 1191 dial is 15 times higher
PostPosted: Thu Jun 08, 2017 2:47 pm
Likes: 116 posts
Liked in: 138 posts
Rene - I don't understand the importance of your comment. Whats the issue if the 1191 dial has a higher reading than your dial? Doesn't that fact that it measures anything at all on the Geiger say its Radium? Wouldn't the reading be somehow proportional to the amount/concentration/makeup of the radium paint originally applied?
PostPosted: Thu Jun 08, 2017 2:54 pm
You said mine or yours was off. I think yours is off in the article I linked to the readings were between 5 and 37 and these were dive watches with better seals & thicker glass. Are you sure you had a correct reading?
PostPosted: Thu Jun 08, 2017 3:14 pm
Likes: 290 posts
Liked in: 514 posts
I didnt see an article linked ?
I am quite sure my reading is correct , compare to this reading of a radium rolex (5.4 microsiev) I assume (by eyeing the amount of lume) the rolex has more lume material than the 1191 dial so emits more
http://www.watchprosite.com/page-wf.for ... i-6840528/
this clip shows (@2.04) 2.44 microsiev
https://www.youtube.com/watch?v=ayghIDng8X8
here a bakelite GMT shows 'only' 9 microsiev
http://rolexpassionreport.com/21770/the ... olex-dial/
so the 21+ is incredibly high , hence I doubt the measurement or tool ?
for comparison , here are some articles with 20 microsiev are mentioned
close to fukushima
http://enenews.com/20-microsieverts-hou ... maps-chart
Radiation Dose: 3.5 microsieverts
Exposure: Lowest daily dose within 30-60km of the Fukushima nuclear plant (3/20)
https://www.allianz.com/en/about_us/ope ... acf094c83e
On March 28, the highest reading occurred approximately 20 km from the Fukushima plant at 78 microsieverts per hour.
http://science.time.com/2011/03/29/fuku ... bad-is-it/
So the measured 21 micro seems awfully high , higher than any other watch that I can see , including old military and rolex watches
PostPosted: Thu Jun 08, 2017 3:17 pm
In the rolex passion report article the readings are 5-37. I have a 1945 Tudor and a WW1 issued pocket watch to test tomorrow.
PostPosted: Thu Jun 08, 2017 3:30 pm
Likes: 290 posts
Liked in: 514 posts
great , please measure a tritium watch as well ?, as reference point ?
 Post subject: Breitling 1191
PostPosted: Fri Jun 09, 2017 1:38 am
Have you got any other watches to compare with to see if your counter is working correctly?
You would expect a Tritium dial to have a zero reading as it emits Beta particles and we are testing Alpha/Gamma particles given off by the Radon-222 gas. (my dad did his degree in physics)
All Watch Sites
